New member Username: DonyahelwaPost Number: 5 Registered: Feb-06 | Check this out. Is it is reliable? Anybody any thought! |
Silver Member Username: The_wank_artistPost Number: 796 Registered: Feb-06 | dsstester is a good site. You'll either have to wait for news or test it yourself. That's why we sometimes call this 'Testing'. |
New member Username: DonyahelwaPost Number: 6 Registered: Feb-06 | well!! I'd rather wait. WRAL is't that bad. thx. I don't realy like jtagging! |
Bronze Member Username: ArgeelhPost Number: 26 Registered: Apr-06 | Donya, This site is great but you might want to check other sites to get the latest updates. I'm glade I have my Arabic channels back. |
New member Username: WeezieNederland, Texas Usa Post Number: 3 Registered: Jun-06 | is there not any spacestar recievers out there |
New member Username: DonyahelwaPost Number: 7 Registered: Feb-06 | Stealth, I have fortec ultra. What do you have and what bin. If you wish! They don't have any fix, yet. How did you get Arabic Channels back?! |
New member Username: UltimatefreakerPost Number: 9 Registered: May-06 | 277 BIN IS GOOD BIN. AND UNLESS YOU DROP YOUR MACHINE IN A POOL OF WATER YOU REALLY SHOULDNT HAVE TO JTAG IT.NITE RIDER LITE AND DEAD "LOOKING" BOX DONT MEAN YOU HAVE TO JTAG ALL THE TIME. |
New member Username: Vasia22Post Number: 1 Registered: Jun-06 | hi guys, iam new to this, I have FORSAT 2500 Ultra , which bin should i use and where i can find that bin whith the loader?? |
New member Username: DonyahelwaPost Number: 8 Registered: Feb-06 | dankauff, got that thx. I'll try the bin. |
New member Username: KoooltecPost Number: 4 Registered: Jun-06 | stealth, how did u get the arabic channals bak , wat reciecer do u have? |
New member Username: DonyahelwaPost Number: 9 Registered: Feb-06 | 277 bin is the same one I have suggested in the beg. I don't think I will try it. Some complains about it. |
Bronze Member Username: CybercubiPost Number: 11 Registered: Mar-06 | Any one know whether there's a fix for the Classic NA yet? |
New member Username: Vasia22Post Number: 2 Registered: Jun-06 | PPL please! FORSAT 2500 ULTRA, which bin? |
Bronze Member Username: CybercubiPost Number: 12 Registered: Mar-06 | Vasia- Never heard of a forsat... Check dsstester.c*om, dsscenral.n*et (remove the *). good luck |
New member Username: NunosondraPost Number: 9 Registered: May-06 | Where can iI get the 277 bin foe fortek lifetime ultr@. Thanks in advance. |
