Username: Moe948 Post Number: 10 Registered: Jun-06
Friday, June 09, 2006 - 04:51 GMT Go to this website (if you have a pansat) www.future-fta.info Register and then go to download section of your pansat reciever. Make sure you post the results here!
Username: Moe948 Post Number: 11 Registered: Jun-06
Friday, June 09, 2006 - 04:52 GMT Just a reminder, the website will be very slow at the moment due to all the people wanting to download the fix..
Username: Neurosis Post Number: 33 Registered: May-06
Friday, June 09, 2006 - 04:53 GMT I wonder when I'll be able to get on....
Username: Cooldude69 Post Number: 34 Registered: Apr-06
Friday, June 09, 2006 - 05:11 GMT dude, theres not fix yet...
Username: Moe948 Post Number: 12 Registered: Jun-06
Friday, June 09, 2006 - 05:15 GMT Really, wow you are a bigger genious than me. Idiot, go the website, register and download the fix. Its from BLACKLIST! The guy who makes bins for pansats!
Username: Dafee99 Post Number: 97 Registered: Apr-06
Friday, June 09, 2006 - 05:18 GMT IM up and running... p2700a (not clone safe remember) thanks
Username: Intlms Post Number: 1 Registered: Jun-06
Friday, June 09, 2006 - 05:25 GMT Will this bin work for fortec LU?
Username: Moe948 Post Number: 13 Registered: Jun-06
Friday, June 09, 2006 - 05:28 GMT No, it will not work for fortec. Just wait some more hours or maybe a day as chancysand will code this for fortec.
Username: Dafee99 Post Number: 99 Registered: Apr-06
Friday, June 09, 2006 - 05:28 GMT i would wait for the clone safe bin (should be out by tommorow)... but its ur call.
Username: Neurosis Post Number: 34 Registered: May-06
Friday, June 09, 2006 - 05:29 GMT works for me, ppv xxx all working. I reset my receiver to factory then did a network scan and entered keys manually. great job, thank you for support. Now what to watch?
Username: Intlms Post Number: 2 Registered: Jun-06
Friday, June 09, 2006 - 05:32 GMT jealous....jealous... Can't wait for my fortec LU bin to come~~~~
Username: Prod_eng Post Number: 1 Registered: Jun-06
Friday, June 09, 2006 - 05:37 GMT How about Coolsat4K,5K anyone? Thanks,
Username: Farazmo Post Number: 5 Registered: Jun-06
Friday, June 09, 2006 - 05:40 GMT ok im just wondering if i use the clone safe bin will it work for both clones and original pansats? reason im asking is that im not sure if i have original or clone receiver. my box and receiver looks all professional and i dont think its fake but i want to be sure and not bust anything up. thank you.
Username: Moe948 Post Number: 14 Registered: Jun-06
Friday, June 09, 2006 - 05:41 GMT I really don't know anything about CS. All i can say is that CS's fix does not depend on pansat's like fortec's does so it will be a total different fix itself.
Username: Intlms Post Number: 3 Registered: Jun-06
Friday, June 09, 2006 - 05:42 GMT i had pansat 2500 before and i loaded my (fortec LU) bin to it and it was working just fine, so I thought fortec and pansat (2500) used same bin. I'm a newb with itch fingers so i'm trying anything. hehe
Username: Cooldude69 Post Number: 36 Registered: Apr-06
Friday, June 09, 2006 - 05:43 GMT ey, fck u moe... ur the idiot
Username: Prod_eng Post Number: 2 Registered: Jun-06
Friday, June 09, 2006 - 05:45 GMT thanks Moe
Username: Cooldude69 Post Number: 37 Registered: Apr-06
Friday, June 09, 2006 - 05:49 GMT but thanks for the link... (i didnt see it)
Username: Ken_ll Post Number: 1 Registered: Jun-06
Friday, June 09, 2006 - 06:05 GMT Neurosis, did you use Pansat 2700A_051121_108_api(N) (Factory BIN file) to reset into factory default first?
Username: Parranda Post Number: 11 Registered: May-06
Friday, June 09, 2006 - 06:05 GMT the bin works i just tested it and it is fine. you can see all the channels on a pansat 3500sd. thank you BL.
Username: Parranda Post Number: 12 Registered: May-06
Friday, June 09, 2006 - 06:08 GMT i forgot to mention that the world cup schedule in the past few bins is great. thanks for that too BL
Username: Josharmour Post Number: 4 Registered: Jun-06
Friday, June 09, 2006 - 06:24 GMT I have been trying to get into that site but it is being hammered! Can someone im me or email it to me?
Username: Josharmour Post Number: 5 Registered: Jun-06
Friday, June 09, 2006 - 06:26 GMT my email is my username plus @charter.net afterwards
Username: Rith Post Number: 2 Registered: Jan-06
Friday, June 09, 2006 - 06:32 GMT Can anyone share the instructions to dowload this file to Pansat3500S Thanks in advance
Username: Moe948 Post Number: 16 Registered: Jun-06
Friday, June 09, 2006 - 06:33 GMT Just wait a few more hours or so most of the people wanting bins would have got it by then. Alternatively, you can go www.dsstester..com (remove the extra dot) and download it from their forums after registering.
Username: Moe948 Post Number: 17 Registered: Jun-06
Friday, June 09, 2006 - 06:39 GMT Rith, you have to know what cable to use with your reciever. http://forums.al7bar..tk/showthread.php?t=83587 (remove the extra dot before .tk This topic says has all info about the cable needed. Make sure to read the top. You have to have the cable required to fix the reciever. if you don't have it then you have to go to your local FTA dealer and get it fixed from there.
Username: Neurosis Post Number: 35 Registered: May-06
Friday, June 09, 2006 - 06:42 GMT ken, i just loaded the bin over my old one (271) then opened menu a did a factory reset, probably can get away without doing that, but I'm a perfectionist
Username: Jose21 MIAMI,
FLORIDA
MIAMI
Post Number: 4 Registered: Jan-06
Friday, June 09, 2006 - 06:46 GMT yes the ppv back and www.future-fta.info and i get the new bin352 and all channel back. thanksssssssssssssssss
Username: Nomeloplagies Post Number: 4 Registered: Apr-06
Friday, June 09, 2006 - 06:48 GMT BL IS the man! ... now we are ready for the FIFA World Cup... looking good everything Echo 1.2, 7, 8.10 (old 8.6) & Nimiq 1.3 ... PPV, ABC, ESPN2, FSC, GalaVision, etc. etc. autoroll ... nice, really nice
Username: Donniew Post Number: 22 Registered: Apr-06
Friday, June 09, 2006 - 11:17 GMT "Can anyone share the instructions to dowload this file to Pansat3500S " Copy the bin to a SD card and put it in the receiver. It's the easiest receiver to load a bin. Go into the menu and choose "SD Card" (or whatever it's called) and select the file you copied. It will load and reboot. That's it!!! You don't need to mess with cables like some other guy mentioned.
Username: Kriskros Post Number: 2 Registered: May-06
Friday, June 09, 2006 - 12:03 GMT Great news, just got a hold of 352 bin, works!!! PPV and HBO up
Username: Kriskros Post Number: 3 Registered: May-06
Friday, June 09, 2006 - 12:08 GMT new working bins at: www.dssc*ntral.net -- look at the retractable sidebar and look for your pansat bin.
Username: Weezie Nederland,
Texas
Usa
Friday, June 09, 2006 - 12:32 GMT does anyone have a new bin for spacestar dvb500?
Username: 1rbjac Long Beach,
CA
US
Post Number: 15 Registered: Mar-05
Friday, June 09, 2006 - 13:14 GMT Thank alot moe for the information.The new bin (277)is working great.
Username: Zunna Post Number: 14 Registered: Jun-06
Friday, June 09, 2006 - 13:26 GMT will dis work for pansat 3000 ?
Texas
Usa
Friday, June 09, 2006 - 13:33 GMT does anyone know of any bins that i can use for spacestar500
