BV adult chanels?
Username: Tnnt97
i have view sat xtreme. I can not see any BV adult channels, i am able to see all other channels include all vue(ppv). does anyone know where is the adult channels at? and how to get them?
Username: Lokbongtom
To avoid harm your existing channel you need to set up any satellite that you never use exactly parallel to BEV antene set up configuration ,and than save it ,after go to to CHANNEL SCAN within the same sateLlite delete all the existing TP in this satellite and save exit and go to back to antene set up and press F2 to do a blind scan with this action you should have all the new Channel that had been move to other TP and save you from losing your existing channel,but you also need the last bin fromm Viewsat
LBT
Username: Iggyship
Gardera, Ca La
I need help with my cools@t 5000. I lost my channels.
Username: Iggyship
Gardera, Ca La
i need help with my cools@t 5000, no channels are working.
