Which loader to use with bin271?
Username: Freshbadboy
Post Number: 22
Hi all,
I just wanted to know which loader should I use to load bin271 to my pansat2700A receiver?
Should I use the loader that was given with bin148 or is there a different one I should use?
Would I be ok with just changing the keys for my bin148 or should I load bin271?
Also, bin271 will only fix the regular channels and not the ppv and international right?
Thanks
Username: Donnie1973
Post Number: 10
I am using bin 148 now. Seems ok. You can use the same loader for 271. U will not get ppv or int.
Post Number: 23
well I have bin 148 and it isn't working, it keeps doing a search 0...400% and then back again.
I have all the auto-roll options off except the first one, and I have the keys that were working until about 4 days ago. Are there new keys?
If so, I would rather change the keys than re-load the bin.
Thanks a lot.
Post Number: 14
Same keys that are all over this forum. Check them again. Mine works fine. bin 148
