Missing ppv on tp 12297 & 12326 @ 110W?
Username: New07fta
Post Number: 40
anyone else is missing those ppv's on those transponders. i did manual scan but no ppv channels.
Username: The_wank_artist
Post Number: 637
Which channels?
And did you check either of these info pages.
http://ekb.dbstalk.com/dishlist.htm
http://www.lyngsat*com/packages/dish110.html
504, 508, 518, 522 and 539 are all still listed at 12297 L, tp 6
Username: Digi6800
I only got 2 ppv (511 and 519), the rest is missing. I tried upgrade the bin and did blind scan but still no help. What did I do wrong? or What should I do?
Please help!
Username: Letmeon
Post Number: 21
119 has only a few PPVs and 511, 519 are on 119 sat. 110 sat has the rest. So your dish should pickup 110 AND 119 ....
Username: New07fta
Post Number: 41
i'll scan that tp today, thanks for the help
Username: Digi6800
I did scan both 110 and 119 sat.
Username: Letmeon
Post Number: 22
Did U do a BLIND SCAN ? That gets different frquencies that could have changed. I always do
blind scan.
Username: Digi6800
I did couple times on both 110 and 119 but still only can get 3 PPV channels. The rest are missing or no signal. I tried to load someone channel list but the same. Any ideas?
Thanks for the help!
Username: Evadelparaiso
Puerto Rico
Post Number: 604
Digiwave try restore factory settings set your receiver, scan.
Username: Pansatman
Bristol, Va USA
wat do u do help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
