World Cup anyone?
Username: Nanotorious
Ca
Hi all, im looking forward to World Cup 06 starting on the 9th, and know that ESPN will be airing it. Unfortunately, I can't seem to get ESPN with my pansat 2700a. I wonder if anyone can give me some suggestions. Is it because of my location? or can I do something to get the channel? Thanx.
Username: Xmongra
I got the same problem, but for channels 455 and 472, those channels are for Sport Events PPV.
If someone knows hot to get this 2 channels, will be helpful.
Thanks
Username: The_wank_artist
Post Number: 570
Try doing a scan of the tp's ESPN are on.
There has been TP movement quite frequently so you're channel list may be outdated.
You could delete all the channels, then do the scan which will remove the dups.
Username: Parranda
Post Number: 8
hey guys, ESPN is in 119 the tp is 8 and channel is 140. it gets better. the new bin for pansats give you the game schedule.
Post Number: 588
SWEET!!!!
GO BELARUS!!!!!!!!!!!!
Username: Evadelparaiso
Puerto Rico
Post Number: 524
How manually enter key for Belarus? I cant find info for c/p :-(
