Ariza xtreme
Username: Rossyjess
Post Number: 8
here the new bin to fix ariza xtreme
application/x-zip-compressedUpload
ariza xtreme temp fix for dn and bev.zip (12.2 k)
Username: Dyson42
I see xtreme has a new fix, is there one for Ariza 700 yet if so where can I find it?
Username: Nsalamoun
Toronto, Ontario
Dear Rossyjess or anyone who can help
Thank you for the fix. Please tell me how to use this fix. I do not know. Should I connect Ariza Xtreme to the computer? and what then. Please give me some details.
Username: Lklives
Post Number: 2792
I have never seen a bin that small that U could post here..something is NOT right!...bins are at least 344 KB or 640 KB..
Username: Rossyjess
Post Number: 9
just try and you see
Username: Tvaddict17
this is an upgrade bin do not use it wipes out all your other channels like it did mine and it does nort repair autoroll CAUTION
This is the Ariza Extreme bin to use S000c146-20000-11055.sgn and it works well honest I am using it.find it on FSFTA Site
To load a sgn file you have to put the loader on Temu then load file then put it back to Prog. Data choose your com # then close port then hit Start then turn on your receiver also use a null chord from pc to receiver hope this helps
