Help
Username: Master_mind
i have a pansat 2500a clone running 274t. i did a factory restore but when i select english i can't go to parental control to put in the code for any sats. can anyone tell me what i'm doing wrong. also i need help finding the file to restore it to it orginal fta settings. thanks
Username: Dafee99
Post Number: 53
since you did a factory restore, you need to do a blind scan on your satellites. set default keys after ur done, exit out and wait for picture
Username: Lklives
Post Number: 2682
U need to do sartellite scans BEFORE U go to parental controls, so it will be hilighted and a working option to get to the 2nd pin 0000.
Username: Jakrichards
Hello all, i have a GR-D270U Digital Video Camera and when i bought it, it did not come with the installation cd, i have tried asking jvc for a copy or even if they could email the program to me but they said it would cost me over 30 dollars for it. I was a little upset considering i had already payed for it. So if any one out there has a copy of the installation cd please email it to me. Thanks alot Jerry Richards
Username: Woofy
Ontario Canada
Post Number: 92
Why are you asking that question here?
