Captiveworks - operation of box
Username: Home1250
Stone Mtn. (Atlanta), GA USA
The cw600s is sold with a "skip channel" function.
I cannot figure out how to do it. If anyone knows how to do a "skip channel" on this receiver, I would appreciate it if you would let me know.
Thanks,
Username: Lklives
Post Number: 2540
Read here..
[link removed]
Username: Jockoin
I'm getting all channels except ESPN! Thanks for anyone's help.By the way, I changed the keys today.
Jockoin
Username: Jockoin
Jockoin
Username: Lklives
Post Number: 2551
Dishnet keys 11 May 2230 hrs
Key 0:
AE F1 0F 87 F9 58 E1 55
3A E4 8B AE ED DB BB DF
Key 1:
15 FD 84 7F A4 D1 CF E9
1C E9 58 70 2D 79 42 D9....Active
Username: Ldcpirate
hey i accidentally did a system restore on my 600s reciever and now i dont get scrambled channels they just show up black itried everything even tried to upload new bin but it wouldnt do it it just said 0% for a long long time never even uploaded can anyone help me get my channels back please!!!!!!!
Username: Johnner
Miami, Florida
Post Number: 171
Search at www.dsscentral.net
SummerV1.48_27012006.zip
http://www.dsscentral.net/uploads/upload/fta5%252edb/SummerV1.48_27012006.zip
last modified: 01-27-2006 )
C&P from there release site:
CaptiveWorks CW600 V1.48 01/26/2006
Here is the new release for the Captive Works CW-600S version 1.48. It include the following feartures and fixes:
-12/24 time choice fix: this include the fix for changing the time between normal and military.
-Satellite Name Display (installers best friend): This version includes the feature that shows you which satellite you are pointing to. Go to installation and choose your satellite nameand put the diseqc number and it will tell you if you are on the right satellite or its a different satellite
Keep your input coming and thanks.
