How to disable autoroll on 2500
Username: Sm92325
Tracy, CA USA
Post Number: 7
I got my panset with no documents at all, so please bear with me. I am having a problem with my receiver holding the keys for more than 5-10 min. I heard that if I disable the auto roll this would (could) be the fix. Any help would be great.
Username: Dafee99
Post Number: 48
best thing to do is get a new bin; the most recent a bin, the more goodies they have to offer you.
what you can do, to make it work, as per posts that i've read in past, ... input the new keys, and as soon as u get programming very quicly change the names of ur satellites. ie. if echo 7 change to excho 7... there is more info on other threads. Anyhow that is a problem that has already been taken care of with updated bins...
just in case, bin 273t has been tested with much succes... 274t is also out--- im currently testing, and so far i could only say that those guys doing the bins are doing something right...
Username: Evadelparaiso
Puerto Rico
Post Number: 291
get the 2273t bin or rename satellite for stop autoroll
Username: Dafee99
Post Number: 50
eva are you currently testing a p2500? cuz if so, the 274t is out and so far its been success... I posted a thread on it. keep up the good work... u help a lot of people
Username: Johnner
Miami, Florida
Post Number: 140
There are NO new keys!...DN is messing with autoroll bins..U have 2 choices..applies to all types receivers..
1..use an older bin and manually input the ACTIVE DN key ...twice
2..use present bins and disengage the autoroll by simply renaming the satellites (Echo7 to Xcho7)
In pansat..menu - installation - edit Tp/sat
now select your sateliites and rename them..exit
Pansat has all new autoroll bins that work but need to rename the sats with the 239 pansat3500 bin..
Bev keys changing constantly..U MUST have a keymaster utility to try and keep current.
Username: Johnner
Miami, Florida
Post Number: 141
LK: Posted on Sunday, February 05, 2006 - 01:23 pm:
Puerto Rico
Post Number: 292
ups 273t bin
Username: Jmill1948
Chester, Va Usa
Post Number: 772
273 works fine.just do a blind san and name the sat echo
Username: Sm92325
Tracy, CA USA
Post Number: 8
Thank you it worked
Username: Bladam
Post Number: 12
Please guide me I am not so sure of how to do a bin change, where I should go to get the files, my autoroll over is having a bit of problem downloading new key automatically, not so sure as to why, i do have the cable to make the connection between the reciever and computer, but I just need some guidence.
Thanks in advance
Username: Grimreeper
Post Number: 89
274t bin has autoroll on/off
