Why ,only getting signal out of 110 but nothing out 119?
Username: Manny
hello all & thanks TYLER 4 your response to my Q last time,, ,,,was wondering if you could help me understand how you can get both 110 & 119,?are they both on same azimuth location??i did some testing ,,i swapped the lnbs & same thing,,,just getting signal from 110,,,& nothing out of 119 wondering why??????do i have to re-aim the dish????? as of now signal strength 88% & sign quality 90%,,,,plz help thank you
Username: Boyce
Post Number: 76
You need adjust skew of the dish
Username: Manny
ty Boyce
Username: Billybeerboy
Carthage, Il United states
Post Number: 24
It would help if we knew what kind of dish,lnbs and what your settings on your receiver are.
Username: The_wank_artist
Post Number: 303
My guess would be to check your settings of the Disqe switch. Make sure that the port that it feeds to is selected as 119 in your antenna setup.
Otherwise, we'll need a little more info.
I have my 119 slightly higher than the 110, by about an inch, but they are strapped together, such as this image. Notice how the one on the right in the picture is slightly higher than the other...
Username: Al_bundy
Post Number: 8
go to megasat usa.com he has those brackets one lnb is tilted and you wont need to skew.
