Help!!! need the lastest bin file for Cooltec 4000pro
Username: Eagle99
Post Number: 15
Hi\
anyone has the lastest bin file for cooltec 4000pro???
Thanks,
Username: Lklives
Post Number: 2553
Dishnet keys 11 May 2230 hrs
Key 0:
AE F1 0F 87 F9 58 E1 55
3A E4 8B AE ED DB BB DF
Key 1:
15 FD 84 7F A4 D1 CF E9
1C E9 58 70 2D 79 42 D9....Active
Username: The_wank_artist
Post Number: 212
It says that your Cooltec 4000 pro is 100% compatible with coos@ 4000 pro. So go here and get the cools@ 4000 pro latest bin...
http://www.dsstester*com/files.php?cat=18
Username: Eagle99
Post Number: 16
Thanks, LK
but I just loaded an old bin file. I need the lastest bin file for my poor cooltec 4000pro. could you pleas tell me where I can get it for free?
Thanks,
Username: Eagle99
Post Number: 17
I just downloaded the version 1.2 for cool*sat 4000pro from http://www.dsstester*com/files.php?cat=18. and loaded on my cooltec. my cooltec is frozen. any suggestions?
Post Number: 213
Power off and unplug, wait a few minutes and try plugging it back in.
Or, try loading a older bin and manually enter the current keys.
Username: Eagle99
Post Number: 18
I tried loading a old bin but that only has 2 key lines. one is for 00 and another for 01. so how can I input the keys?
thanks,
Post Number: 214
Well it depends. If you can enter only 16 characters per 00 line, then just enter the first 16 of the active in 00 and the second set of 16 in the 01 line. If the 00 and 01 each hold 32, you can enter the full set, as posted above by LK.
So you loaded an older bin and the box is not frozen anymore? If so, try loading the new bin again.
Make sure the bin is for the cools@ 4000 pro, not a 5000 or 6000.
Username: Eagle99
Post Number: 19
I have loaded the bin for coolsa*t 4000 but still froze. my cooltec is DiSEqc 1.2. do you know what the DiSEqc 1.2 means?
Thanks,
Post Number: 218
Diseqc is what looks like a splitter and is used if you have more than one LNB or two lines coming out of one LNB. When you use a diseq switch, multiple lines feed into it and come out in one cable that you run to the back of your box. You then can use the antenna settings option in the box to let it know which LNB comes into which port on the diseq switch.
If you only have one LNB, then the switch should be set to number 1.
If you have more than one LNB, you'll need to know which LNB (or sat signal) goes to which port of the diseq, and change your settings in the box accordingly.
Username: Eagle99
Post Number: 20
Thanks very much.
I need the bin NORW-ver1.01P for cooltec. do you know where I can find it?
Thanks.
Post Number: 220
Eagel99.
You didn't spend too much time at this site below researching did you, even though they have a special section all about your box. I've been there all to 2 minutes and I think I've found the answer to your problem (but I didn't read all of the thread so maybe not).
Anyway, the bin you tried to load but locked your box up has a patch to be installed which (it would seem) fixes the bug in the bin.
Read this and maybe you'll be able to use that bin after all.
http://www.curious-contraptions.com/forums/showthread.php?s=0ca13249f29d28b8cc76 afd01a79fc1b&t=29330
Because of this laziness, I will now refer to you as Eagle98!!! You have lost one point.
Username: Lklives
Post Number: 2556
Over 10 patches have been made for those cooltecs...they all suck...Only #8 and #10 worked, and then they were defeated again by co*olsat...and ONLY sometimes do mods #8 and #10 work on OLDER bins which are terrible...even Mingo has little faith with these cooltecs..get rid of the garbage!
Username: Eagle99
Post Number: 23
Thanks, you guys
I just reloaded the NORW v1.01P. My reciever is working now but I still get scramble channels. I have tried many combinations to input the new keys but no luck. Is there anyone really know how to input the keys for cooltec CORRECTLY???
Thanks,
Username: Evadelparaiso
Puerto Rico
Post Number: 242
eagle99
https://www.ecoustics.com/electronics/forum/home-video/184799.html
there are all the instrucction, if you need more help post again. Lucky
Username: Eagle99
Post Number: 24
Eva,
This is the key editer looks like. I can change any item on this screen. I have tried many combinations but no luck.such as 00 00 01 01, 10 11 20 21,10 11 10 11 or even 00 01 10 11.
My reciever is 3-button cooltec and with bin file NORW-v1.01P. I dont know if there is a new bin file available.
By the way, thank you so much for your helps, buddy
Puerto Rico
Post Number: 256
Key 0: is for space 00
Key 1: is for space 01
The cas at that picture is ok
and ID for dishnet is 0101
Puerto Rico
Post Number: 257
MANUAL KEY ENTRY INSTRUCTIONS FOR C***OOLSAT PRO 4000:
Instructions for Dishnet:
Find and select satellite tab: NAGRAVISION (00 01)
Once you locate the above mentioned tabK
You must change the values of that screen to this:
10: XX XX XX XX XX XX XX XX
11: XX XX XX XX XX XX XX XX
00: 00 00 00 00 00 00 00 00
01: 00 00 00 00 00 00 00 00 and save it.
If the above key entry instructions does not work for you on dishenet (NAGRAVISION (00 01)?
Change it to the instructions indicated above to the one illustrated below:
(Remember: This XX characters whould be replaced by the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
20: XX XX XX XX XX XX XX XX
21: XX XX XX XX XX XX XX XX
(Notice: That the #10 and #11 above are now #20 and #21 on this sample)
On some receivers, this is the only way it works!
Username: Eagle99
Post Number: 25
Eva,
I have tried this new key but did not works.
In the Ident field, I could not find Dishnet 0101, only can find Dishnet(0001) and an option for 4 digits to enter. so I enter 0101.
did I make myself clear?
Thanks,
Puerto Rico
Post Number: 258
eagle please read up.Find and select satellite tab: NAGRAVISION (00 01)
Username: Eagle99
Post Number: 26
Hi Eva,
Thank you millions,It works. I got everything I wanted.
Na#1 Dishnet(001)
You are wonderful!!!!!!!!!
Puerto Rico
Post Number: 261
You welcome.
Username: Lklives
Post Number: 2589
Ce site soutient anti les idéaux américains et anti- anglais parlant. ....so écrit dans n'importe quelle langue que vous voulez, brulez le drapeau et les facons américaines ...and spectacle disrepect total pour tout anglais parlant des membres ici. ..eva syas son bien et elle doit savoir la cause elle est un 11 bleu de jour ici qui est un Riciens de Purto. ..and Riciens de Purto ne paie pas d'impot et peut faire quoi qu'ils veulent a n'importe quel endroit ils Les déchets ces forums les je dis laisse TOUS forums de theses de déchets que j'ai travaillé dur pour développer et maintiennent dater.. bien maintenant son temps pour le démolir !
Username: Kato1
thank you for all your help how can i get the keymaster 2.0?? you are all the greatest!!
Username: Kato1
sorry about all the questions...but i have to ask..thanks tyler
