Diseqc and splitter
cheetos
hi. i have the dish 500 and two receivers conneted to it but i want to connect my pansat 2500a from the cable that thats for one of the receivers but i have a splitter i know i need a diseqc or what ever its called but i only have two splitters i want to know which one is good
one of them is a two way splitter its 5-900mhz
and the other one is a 3 way splitter 5-1000 mhz
but the out put things one of them is -3.5db the other one is-7.5db and the third one is -7.5db which one should i use rememberi only want to connect two receivers to one cable
Username: Lklives
Post Number: 1002
U cannot hook 2 receivers to 1 cable and have working receivers!..
cheetos
yeah i can cuz thats what i did it works but i don't get good quality
Username: Lklives
Post Number: 1013
If U call that working, then go buy some rabbit ears and a coat hangar...they are just as good!
