New member Username: Mav444
Post Number: 7 Registered: Jan-06
Posted on What bin to use,and where can I find it? |
Bronze Member Username: Kneegrow_2
Post Number: 13 Registered: Feb-06
Posted on heres the link:
http://forums.al7bar.*tk/showthread.php?t=113396 (remove the star in front of tk |
Post Number: 8 Registered: Jan-06
Posted on Thanks knee grow,but cant get to that link for some reason,but I'll keep trying, thanks again |
Post Number: 17 Registered: Feb-06
Posted on did u take out the star from the link |
header108 Unregistered guest |
Posted on Use the 270t bin I have it running on my Vortec Pro 7700 no problems and it auto rolls |
Bronze Member Username: Mav444
Post Number: 12 Registered: Jan-06
Posted on Thanks to you too knee grow,found it thanks for the help!again thank you header108 for your help also! Mav444 |
