Scan problem
Have pansat2500 when I do a blind scan all tp come up, but channels and radio are 0 found.
please help.
Username: Lklives
Post Number: 266
sounds like bad disque switch or dish not aligned..or receiver not configured to the LNB's and disque switch...
sb3cb
Thanks LK will change switch and see if this solves problem. how should the LNB'S and switch be config.
using two dirtv dishes with sw21
Username: Lklives
Post Number: 268
Cannot use sw21 switch with FTA receivers..
J Roo
LK
I am using a sw21 with a dish 500 dish, and a c---sat 5000 . I have no problems with this switch.
Username: Lklives
Post Number: 272
U are very fortunate..
SB3CB
LK
Did away with sw21 switch. Ran cable from dish
to pansat 2500 did blind scan. Still have same problem 0 channels found.signal level 84.
Username: Lklives
Post Number: 317
U have some defective hardware,if U ran RG6 cables directly from LNB's to receiver and have NO channels after doing a scan..U should at least get the free FTA channels,if U don't have the latest bin uploaded,if not U have bad hardware....LNB's, cables, connections, receiver etc..
I know there is something VERY IMPORTANT that U are not telling us..this is a wild goose chase with the little info U provided..
Username: Lklives
Post Number: 318
also U must align dish towards the 110-119 if U want dishnet channels, have U done that?
SB3CB
Both dishes are aligned. sig 84 on 110,82 on 119
Have channels now on both sats.
Trying to scan and get channels that have changed
tp's.
after loading bin in dec.Scanning went fine no problem.
Tkanks for your responce.
Username: Lklives
Post Number: 320
what fixed your scanning problem?...what bin are U using now?
Username: Lklives
Post Number: 321
and what bin were U using that wouldn't allow scanning?
SB3CB
Sorry for confusion have not scan again since december. Have been tring to blind scan
to get channels that have changed transponders.
Not at reciver location now and can't remenber last bin file loaded.
SB3CB
bin 256
