Lifetime ultra problem.......
Username: Momenali
i have a lifetime ultra reciver, i hooked up the dish and i get very good signal on echo7/119
and i made sure the key i put on nagrivison
was correct for both keys 00 and 01 on dishnetwork provider. when i go to a channnel
for example MTV...i see really high signal but nothing is showing....could it be because the codes have to be in nagra2?....if it is, how do i change it to nagra2?....it iant leeting me...it says to put a password when i push the side buttons on nagravision.anyone got any ideas ...whould really be helpfull. thank u
Username: Honey
help plzzzzzzzzzz :-( i got fortec star and im trying to put the keys but its still not working.....anybody can tell me how to fix this ?????? :-( thxxxxxxxxxxxx
Username: Lklives
Post Number: 180
Dishnet 20 Jan
N 0101 00:
9E 5B 7A 77 C0 FE 91 CA
4D 2A DC 33 D4 CD E3 75 ....Active keys
N 0101 01:
FB D9 F2 D9 D6 C9 EF 7A
57 AD 32 24 67 42 6C E6
Username: Momenali
Post Number: 8
still not working man what do u thinck i should do next?....thanks tho
