Wanna be newbie questions
sparkey
I have read several hundred pages of info on fta and belive I have most of the basics, but would a moterized system be better than multiple lnb's?
also not sure of what the acronym bev and nag2 are are these ecm programs?? and how often do the codes change on avg? LT & Maple Leaf you have posted a lot of helpfull info
thanks
sparkey
Is there any real diff with rg6 and rg6quad I know there is a 2nd layer of sheilding but is this really needed if there is not much RFI?
+ quad cost 30% more and will not fit my standard digicon f fittings
Username: Ssenow
Post Number: 7
I am new to the game as well. From what I gather,RG6 is plenty fine for the job and I will be going with the combination of a 2700A (not clone) and a DISH1000 from Dishnetwork. Alot of people have the SUPERDISH, but the 61.9 LNB soon will not be used. The DISH1000 will give you 110, 119 and 121.
Hope this helps.
sparkey
Thanks J.S. :-) I was thinking this site was a waste, the only info I could find was old and took massive amounts of reading.
A firend gave me a single lnb dish to try as my old 12' dish is in bad shape.
Havent tried sats since before I went into the service and I am retired now,, things have changed alot since I built my first LNA
sparkey
Username: Ikaleem
Post Number: 49
Here is some info
BEV: Bell ExpressVu...It is a satellite provider from Canada
NAG2: Nagra2 is an encryption used by both bell and Dishnet
They keys on bell change everyday...Dish net last changed the keys on Dec 20
You are okay with RG6
sparkey
thanks Wiz, with auto roll bin how often do you loose or need to update keys? looks like bev would be a pain to keep updated...
