Fortec programming
Pls i need help on how to program a fortec, i am new at this.
eyeintel
Check this site for instruction. It may help you
http://thedishguy.com/fortec.htm
Username: Sholooloo
i hv a programmed fortec and it went down in the last few days and i want to be able to enter the new keys and programe it but dont know how.
Username: Djmobility
Is the programming the same for a fortec classic as it is for Fortec Ultra? Any insight on the classic model would be appreciated. there seems to be a lot on th eultra but not too much out there on the classic.
eyeintel
Believe it or not all non-prescribe satellites went down.. Fortec went down on the 6th of Dec. I'm trying to test my recent bin for ultra not classic. If I get the satellite up and running. I'll drop the 411. But meanwhile, I'm having problems with connecting my receiver to my computer due to not have a Male DB9 and I'm attemptting to re-route it to a serial port Printer port) or USB port need help if you can help.
eyeintel
Username: Sat
Y, Y N
Post Number: 29
let me know if you have a fortec ultra
