Duplicate Channels
Username: Rana
The search feature does not produce any results and I went through lot of posts for a solution.
I did a blind scan and have all the 3 satellites, the only problem is I have duplicate channels showing up. Could someone help please, Thank you.
How about going into your Channel Manager, view the duplicates, and delet the ones that dont come in...pretty basic stuff!!!!!
Username: H3lt3r_sk3lt3r
Post Number: 552
@Rana
OR you can always load a channel list.
chespirito
How do you load a channel list ?
Post Number: 592
@chespirito
You use your existing serial cable and a Channel Master (depending on which receiver you have, google it).
chespirito
What do you mean by channel master I got pansat 2700.
Post Number: 593
@chespirito
It's a program for editing channels and uploading them to or download them from your receiver.
Username: Hawk1
I have a pansat2500a, is there a way to get a guide, some channels show what's on, but a guide would be great!
Thanks to those who give out good info. I think these sites are great....Anyone know of any RFID forums?
Username: Thehitch
Fla.
Post Number: 142
Hey Rusty, count down 14 threads from top and all the help you need is listed there. The clue is in the title "try these sites for help files".
