STEPS: ARIZA 700 MANUAL KEY ENTRY.. HERE!!!
Username: Random_guy_2004
How To Change Keys Ariza 700
1) Press Menu
2) Scroll Down to Parental Control, Press Enter
3) Press "i" key on remote, then enter pin number "2004"
4) Scroll down to Set Default Key, Press Enter
5) Scroll up to Nagravision, Press Enter
6) Press VOL Right twice, you will see Dish Network
7) Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left
8) You are now at the key 00, Press CH Down once so you can edit the Key Data
9) Enter your new keys (write down the old ones to be safe)
10) Press Ok to store, then repeat with key 01
11) Press exit until you get back to tv, all channels will be available
ALL FRUITS RIPE!!
New Keys:
Key 00-F29874441C6577D8
Key 01-17E3E11D894E5345
Username: Thill1951akalk
Post Number: 593
How To Manually Enter N2 Keys For Ariza:
Press 1- Green button 2- Red button
3- Red button
4- Menu button
5- Press right arrow several times until you see nagravision
6- Now depend on the key that changed and it is active you must scroll down til proper key to be changed
Example: On 06/09/05 ECM key 01 is active. Scroll down to provider 000101 01 key line and enter xx xx xx xx xx xx xx xx (enter number with your # button in your remote and for letter follow code definition button on your TV screen)
7- Press OK for 5 seconds.
8- Exit,exit...........
