DISH 500 & DISHPRO LBN HELP PLEASE
Username: Slo_hand2
Post Number: 11
I have a dish 500 dish and a dishpro lbn setup, I am using a Pansat2700A with a DiSEqC 4x1 switch but can not get any quality signal at all. The level is at 80% at the moment.
I also have an old sony single lbn dish that I used when I had directv, this dish works fine by it self I guess Im getting echo 6,8 with it,the first channel is the history channel international.
When I try to use the dishpro I get nothing.
I read somewhere that I have to change all the horozontals to vertical (TP EDIT) but not sure and before I do this I need to know if that is correct?
I want to get the best use out of the dishpro lbn's but as you can see I'm not, can anyone help?
My Lat is 34'3.348N
my long is 78"54.966W
I set the AZ to 237"
the el @ 35
and the skew at 130
can anyone confirm these figures for me? please!and tell me what else I might need to do to get a signal.
any help would be appreciated
Username: P2b
Try these
[link removed]
http://forums.al7bar.t(k)/showthread.php?t=73762&highlight=pansat+2700a
http://www.lyngsat.com
HTH
The P2b
