Sat Rcvr Simultaneous HD & SD Output
Username: Kenamcneill
I currently have a new DishNetwork 921 HDTV Receiver but just like the 6000 I replaced, the Sat Rcvr will not simultaneously give me an HDTV output (Component/DVI) and Standard Definition (RF/Composite). My application is simple. I have a family room with an HDTV Plasma in the Pool Rm area and a separate bar area that has two TV's installed (fed by RG6 coax). I want to watch the same program on the Plasma (in HD) as the two smaller TV's (in SD) at the bar, but the Rcvr will only do that if I select the SD (standard definition) mode. Then the Plasma is in SD as well (and looks like crap). Does Direct TV's HD receivers offer both outputs live simutaneously? Is there a box that accepts a component video/DVI input and deliver multiple output flavors (CV, DVI, RF and Composite)? Is my only option to order another SD Rcvr for the bar TV's(I'm maxed out on Rcvrs in my home)?
Thanks for any feedback folks. Kindest regards.
KM
