Missing some transponders on fortec ultra - superdish
Username: Tbp
hello all,
i just got a fortec ultra lifetime. i am using it with a dishnet superdish picking up 105-110-119. dish works great with a dishnet 311 receiver, signal in the 90's. problem is, with the fortec....i am missing bands of channels, no signal strength. meter is pegged out on the TPs that work, but have 0% on the ones that don't work. each sat is missing several TPs.
i don't expect to get every channel, but i am missing some major networks, such as USA, CourtTV, P- boy, my locals, etc.
each lnb has its own wire, no internal switches. i have taken out the dishnet switch that the lnbs run to and replaced with disequec, but still no luck. it is the same with the big switch that came with the sat or with the diequec. again, like i said, a dishnet box picks them up fine. but on the fortec, in the antenna setup, the three sats are pegged out, but when you do a channel search, it only gets certain TPs. the channels that work, work fine. could a signal booster fix this? or am i missing something?
thanks in advance
