VCR to two tv's
Mrs. Tierney
I am a second grade teacher. I have a visually impaired student who can not see our wall mounted television. She needs a television up close. We will buy one for her. I know how to split the cable. But, I don't know how to get my vcr to play on both televisions. Any help you could provide would be great.
Username: Samijubal
Post Number: 500
Use a 2-way splitter on the output cable and hook to both televisions.
Mrs. Tierney
So, it is the same idea as the cable splitter?
Mrs. Tierney
Username: Samijubal
Post Number: 506
Yes, just split the output. Unless you're using a long cable run there shouldn't be any noticable signal loss.
Mrs. Tierney
thank you
