Jpegs on iPad
Username: Lowteck
After spending a decent chunk of change on an adapter that accepts SD cards for my iPad2 I drag a few videos and jpgs to the card from my PC yet only a few uploaded Hearing that some SD cards work better than others I buy a Verbatim SD card and alas NONE of the jpgs upload off of it... Is it the cards or am I doing something wrong I so want all my photos from my camera and PC on the iPad one of the reasons I bought it in the first place! lowteck@q.com
Username: Project6
Post Number: 15908
It is not the card. The file size could be the problem and also, if you are moving RAW files.
Username: Project6
Post Number: 15909
Are you using a camera connection kit?
Need to Register?
Forgot Password?
Enable HTML code in message
