Forgotten security codes
Username: Byrd7586
Shannon, Ms United states
I bought a razor v3 from a friend, but he for the security code he put on the phone. How can i reset or over ride the security code with out having the security code to start with
Username: Gamerhenry
Mesa, AZ USA
Post Number: 10
Try the last four digits of your phone number. If that doesn't work, then call your service provider. They should be able to help you reset it.
Need to Register?
Forgot Password?
Enable HTML code in message
