FM reception
My department is located in the basement of our building. Is there anyway to improve the FM reception of my portable stereo? Certain spots can pick up weak signals but most areas cannot pick up anything. Tired of listening to the same cd's over and over.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 569
Try alluminum foil, lol
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3559
does that really work.lol
Username: Project6
Post Number: 5070
isn't foil for keeping aliens from scanning you...lol
Username: S_dot
United States
Post Number: 90
sometimes aluminum foil works.. it also does indeed stop aliens from scanning you. makes a great baseball too if you dont have any tennis balls around
Need to Register?
Forgot Password?
Enable HTML code in message
