LOGIK 10-OFM512 MP3 PLAYER
Username: Wody
I BOUGHT THE LOGIK 512MB MP3 PLAYER ABOUT NINE MONTHS AGO FROM CURRYS,THIS IS A CURRYS OWN BRAND...NOW IT WON'T WORK KEEPS ON FLASHING "SEARCHING FILES" AND THEN "COMPLETED" AND JUST CARRIES ON IN A LOOP...CURRYS CAN'T/WON'T HELP BECAUSE I DO NOT HAVE THE RECEIPT AND BECASUE THE VALUE IS LESS THAN £100 ARE BASICALLY NOT INTERESTED, I DON'T MIND PAYING TO HAVE IT FIXED BUT IT'S A DEAD END...HAS ANYONE HAD A SIMILAR PROBLEM?..ANYONE GOT A SOLUTION?
Username: Screwthemasses390
Arizona United States
If it's searching for files there might be corrupt files or files that didn't delete correctly when you formatted it.
I would try formatting it, and putting your songs back in. And if you don't have it fixed then, it's a paperweight until you get it fixed I suppose.
