Napa player and folder navigation
Vidal
Hi all.
I've just bought a Napa mp3 player with 1GB. The problem is that it doesn't allow folder navigation, so it is very problematic to play a specific song.
It uses firmware updater SigmaTec MSCN and the version of the firmware is 003.000.393
Does anybody know if there is some firmware which allows folder navigation?
Cheers
