6 ohm speakers on yamaha rx-v440rds
Username: Kloss
hi!
I need to know if i can connect 6 ohm speakers to the main connectors on my rx-v440rds without any problems?
The manual says to be exact: "Main: if you use one/two set(s) of main speakers, the impedance of each speaker must be 4/8 ohm or higher". Now what does it mean? That you can connect any speaker with a impedance between 4 and 8? or only 4 and 8 ohm speakers?
Username: Geekboy
Newport, RI United States
Post Number: 353
John: that would mean that you could connect 4, 6 or 8Ohm nominal speakers. There aren't alot of 6Ohm speakers out there, so many manufacturers rate their amplifier (sections) for 8Ohms and/or 4Ohms.
If your receiver is rated for 4Ohm speakers, it will have no problem with 6Ohm speakers. Generally, most receivers which are rated for 8Ohms would have no problems driving 6Ohm speakers anyhow.
Username: Kegger
MICHIGAN
Post Number: 1365
geekboys got it on that one.
Username: Geekboy
Post Number: 366
Kegger: I was wondering how you got Gold and 1365 posts... :-)
Username: Kegger
MICHIGAN
Post Number: 1373
hey now i haven't even posted in like 2 days. lol
i was just backing up your answer. i could of gone in detail
but you had it covered bro.
some people need confirmation to truly believe what they are hearing.
that's all dude. anyway have a good one.
Username: Geekboy
Post Number: 369
Kegger: I know, just bothering you.
