Blown Bose tweeter
toddo97
I have a pair of old 4.2's that I've had laying around for a while. I hooked them up to see if they still worked, and found out one of the tweeters is blown. I took the grill off and found a couple of small tears. Does anyone know where I can get a replacement tweeter or know of another brand that would work instead?
Username: Edison
Glendale, CA US
Post Number: 540
May be it's a blessing in disguise - time to upgrade maybe?
There are many you can do better with these days, like www.ascendacoustics.com cbm-170.
I wouldn't put money in to Bose if I were you.
You are in for a pleasant surprise when you get better stuff - your ears will thank you.
Hope this helps,
Sorry to disappoint you with Bose, but no audio-lover seems to like them.
Toddo97
Don't worry--I upgraded a while ago to a full Onix Rockets setup. That's why the Bose have been laying around not putting out music. I wanted to replace the tweeter to either give them to my brother who hasn't gotten spoiled on good speakers or to try to sell them. Thanks for any replies.
Username: Project6
Post Number: 1254
you should be able to find a shop that can fix those. Check out your local area.
