Kenwood Vr-6060 and DVD-Audio & SACD
Username: Haleirwin
Caracas, Caracas Venezuela
This receiver is compatible with DVD-A and SACD? this receiver has 5.1 analog input and a/d, d/a 96 khz 24 bits. For multichannel listenig this receiver take full adventage of the quality of DVD-A and SACD?
Username: Landroval
Post Number: 609
Yes. The 5.1 analog input is the only thing you need to play DVD-A/SACD.
Username: Haleirwin
Thanks for your answer Landroval. I have another question. In this case is important the quality of converters (96 khz 24 bits) or not important?. Thanks a lot for your help.
Username: Landroval
Post Number: 610
It has no importance because the DA-conversion will be made in the DVD-A/SACD player. There is no other choice unless you have an i-link or HDMI connection between the receiver and player.
