Is their a way to make ps2 use a coaxial coard
Matt Whitesides
i was useing my optical coard for my xbox and that used up the optical coard space so now i dident want to keeps swicthing the coards from my ps2 and xbox and no offence but ...... xbox is better and its games have in game 5.1 and ps2 dosent but i still wanted digital audio and not use the anolg so i saw i had a free coaxial space and i wanted to use it for my ps2 if i could
Matt Whitesides
did i put this in the wrong section thing ... yeh i think i did but can u guys help me out
marky mark
learn to spell, loser
Username: John_a
Post Number: 1955
Matt,
Probably you should try that question somewhere on Video Games - Hardware.
Username: Kegger
MICHIGAN
Post Number: 1113
i have an xbox but i don't believe you can have
a coax connection.
i believe it's only optical.
also i have the ps2 and belive that is only optical.
so if you only have 1 optical input you will need
to unplug one to use the other. or like you said
use the analog input for the ps2. unless you have
something else on your reciever plugged into the
optical that you could use coax.
