2 subs or one and hookup of 2
Username: Norm
I'm debating on buying 1 velodyne cht-12 or 2 cht-10's for a large room. Recommendations.
And if I get 2 cht-10's how do you hook them up.
Can I run speaker levels L&R to sub1 and continue from speaker input on one to speaker input on the second sub???
Dwight
With 2 subs this would probably work, make sure your speaker connection polarity stays correct throughout.
Norm, have you thought of hooking them up in the following way:
Left and center to one, right and center to the other. Then place the subs, next to (or below) the corresponding speaker for better impact. That would give you true stereo subs, instead of the same signal split out to two, plus your LFE sound will come from the front of the room which, from my experience, will give you the best sounding impact when listening to music and movies.
