2 subs or one and hookup of 2
Username: Norm
I'm debating on buying 1 velodyne cht-12 or 2 chy-10's for a large room. Recommendations.
And if I get 2 cht-10's how do you hook them up.
Can I run speaker levels L&R to sub1 and continue from speaker input on one to speaker input on the second sub???
Username: Cooldudejz
getting two subs helps increase the overall sound and spls coming from your system. two is always better than one. their are many different ways u can do this. one way is to use the speaker levels. connect your fronts to one sub and your rear speakers to the other sub. or u can buy a Y splitter. i have heard of people using a Y splitter and connecting one to one sub and another to another sub. this is how u would do this. connect the Y splitter to the receivers sub out. and then buy two subwoofer cable. the cable make all the difference in the world i think. then connect each sub cable to a different subwoofer.
