Crate CR-1 Amplifier
Username: Moosewala
I bought an old Crate CR-1 amplifier with two burnt out resistors. I’m currently working on determining the value of each resistor but rather than just replace them want to get some thoughts about why they burned up.
Any ideas?
No sense replacing them only to find out the burnt resistors where the symptom not the problem.
Username: Magfan
Post Number: 3602
Do you have access to a schematic? How knowledable are you dealing with what I presume is a tube amp? Have you checked the tubes? Is the speaker OK?
I'd say to get a schematic FIRST.......
Need to Register?
Forgot Password?
Enable HTML code in message
