Bose Life System L25
Username: Hoppyb1
Ocala, FL United States
Display on Music Center does not light. Being a newbe with Bose does the 8 pin cable from the accustimass speaker have to be connected for the display to work or just the 12 volt supply.
Username: Jan_b_vigne
Dallas, TX
Post Number: 18710
not the forum to ask. everyone here has a dislike for bose and can't tell you anything about the way they do their designs. this should be a simple answer if you contact bose support.
Need to Register?
Forgot Password?
Enable HTML code in message
