Retro home audio system
Username: Snomise53
I am setting up a retro music center to allow playing of LPs that I have collected over the years. I have a Crown DC300A power amp and an IC150 preamp. But I also have a lot of music on my network server and I tunes that I would like to able to access. I don't have to use the old components and I wouldn't be opposed to having a laptop at the center for access to the network music. Am I better off just buying a new controller? I'm looking at bookshelf speakers with a sub. Of course the older components are not blue tooth or wifi capable. Not sure what direction to go in.
Username: Jan_b_vigne
Dallas, TX
Post Number: 18517
Well, that leaves a lot of "ifs" left unanswered.
If you have a sufficient number of unused analog inputs, buy an external DAC. Run your digital sources into the DAC and run the DAC into your pre amp.
Need to Register?
Forgot Password?
Enable HTML code in message
