Connecting 80's/90's-era turntables to 70's-era receivers
Username: Wrecka_stow
Lincoln, NE United States
I have several Technics turntables that work perfectly when I use them with my newer receivers.
However, I'd like to use them with some vintage 70's receivers I've acquired (all have PHONO inputs). When I hook them up, they play...but on a VERY low volume. I have to turn the volume all the way up to hear it at all. Volume works fine if I'm listening to the radio.
I thought if a receiver had a PHONO input, you were good to go. Am I doing something wrong? Let me know if you have any ideas why these components aren't playing well together.
Username: Jan_b_vigne
Dallas, TX
Post Number: 18441
A '70's receiver should have a working phono pre amp. CD's weren't introduced until the early '80's and receiver didn't begin losing phono inputs until late in that decade.
What phono cartridge are you using?
Need to Register?
Forgot Password?
Enable HTML code in message
