Bose 321 series iii loud buzz from subwoofer
Username: Troydixon
hey guys,
Can anyone help me correct the buzzing sound comming from my Bose 321 sub. The sound is loud even with the volume turned all the way down on the system. Used bose cables to connect to the unit and all other connections HDMI to tv. It does not matter what source is selected.
Thanks, Troy
Username: Jan_b_vigne
Dallas, TX
Post Number: 15561
Could be a ground loop. Are the sub and the receiver both plugged into the same AC circuit? Same wall outlet?
Is this a new system? New set up? Or, something that just started to be noticeable on an old system and set up?
Username: Sorinelionut
Pls. I have the same problem, how can you take the front panel of the subwoofer,i couldnt see any screws in front of it,is it glued.
Need to Register?
Forgot Password?
Enable HTML code in message
