Suggestion on old HK 730
gregory b
I have an old HK twin powered 730, which after almost 30 years still performs as well as the day I bought it. Couple questions, the system allows for the addition of a pre-amp and I'm looking to change my speakers. What would you recommend for a set of speakers, around $500-700, and would you recommend adding a preamp and if so, what would you suggest?
