Ipod connectivity with older Onkyo CR305TX
Username: Kandksmom
Looking for a way to let daughter use her ipod with the great Onkyo system that her brother is passing onto her. From what I can see there is no way to connect her ipod to the Onkyo. I found an Onkyo DS-A2X that is in our budget ($100-150) but I have no idea if it will work and if so, how- where does it plug in? If this isn't a good choice, could you offer any other suggestions? Thanks for your help!
Username: Klepsydra
Post Number: 8
You can connect the iPod directly to any RCA line inputs on the Onkyo. You just need 1.8" headphone to RCA cable.
If you would be able to control the iPod with a remote I would recommend buying the iPod dock that will give you remote and line outputs to connect in the same manner.
http://store.apple.com/us/product/MB125G/C?fnode=MTY1NDA0OQ&mco=MTA4MjUwNjc
Username: Maxepotter
Having looked at their web site I would like to explore their more sophisticated products for my main home use, this is ideal for small room use ...
Need to Register?
Forgot Password?
Enable HTML code in message
