Bose am9p please help
Username: Paikens09
i have the bose am9p subwoofer i bought it it worked great my power cord had a fray in it now the sub wont work not sure if there is an eternal fuse or what else could be wrong thanks
Username: Plymouth
Post Number: 15289
Joe
Test your Power cord or replace it!
Username: Paikens09
i tryed a brand new one no luck any other ideas or does anyone know if it has a internal fuse or how to open it up without breaking it?
Username: Plymouth
Post Number: 15291
Yes there is a internal fuse!
http://myboserepair.com/acoustimass%20dissassembly.htm
http://elektrotanya.com/PREVIEWS/63463243/23432455/bose/bose_amp9l-cs6-ls6-am25p .pdf_1.png
Username: Paikens09
do you know where the fuse is located or round about whereshould i look so i only go as far as i have to also do you fix these? thanks for all your help
Username: Plymouth
Post Number: 15309
Sorry Joe but I don't know your sub!
You can send a mail or call the expert of Bose at this site:
Need to Register?
Forgot Password?
Enable HTML code in message
