Marantz CD 5004 or NAD C 545BEE?
Username: Bz1994
CalgaryCanada
Hi Everybody!
I hope that someone will be able to help me with my decision. I'm looking for a new CDP.
I own Marantz receiver SR7001 and I'm very happy with it. I also have older Nakamichi receiver, good sound too. I have 5 Keff speakers. Movies sound great. For listening to music I use old CD player Denon DCM-270 (5 disks).
I don't know which CD player to buy. I was thinking to get Marantz CD 5004, or maybe NAD C 545BEE.
If I would notice a big difference in the sound quality I might go with Cambridge Audio or Arcam.
Is it better to have receiver and CD player of the same brand or that has no benefit at all?
I'm open to any suggestions
I can't wait to hear your opninion!
Username: Edison
Glendale, CA US
Post Number: 943
All the ones you mentioned are good but I would go with emotiva or oppo :
http://www.consumersearch.com/cd_players?gclid=CP-TrOmQlaQCFRFW2godtiiuHw&ef_id= 1953:3:s_adf011bf615f5fe094e0e293d60e3f03_5031519862:TJbeAwqoEEQAAE06EhUAAAjL:20 100920040731
Username: Bz1994
CalgaryCanada
Thank you for your response. I never heard of Emotiva but it does look pretty good.
I"m open for other suggestions
Username: Artk
Albany, Oregon USA
Post Number: 13218
I think the Marantz CD5004 is the best match for your setup and reasonably priced with a nice warranty.
Username: Nuck
Post Number: 15408
Might be a bit of symmetry there Art. What cables do Marantz have on board, I wonder?
Username: Bz1994
CalgaryCanada
As I've asked before:
"Is it better to have receiver and CD player of the same brand or that has no benefit at all?"
Username: Stu_pitt
Stamford, Connecticut USA
Post Number: 4007
Generally speaking, it's better to keep it one brand. They're usually designed to work together and voiced together. Every now and again a company makes a clunker that just sounds bad, but the Marantz CDP you mention isn't one of those.
I'd be willing to bet that the Marantz CDP would work better in your system than the NAD CD player. The NAD CD player may be a bit better sounding in another system, but probably not yours.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15321
my nad cd player quit in less than a year i think so I dont have much faith in them anymore
Username: Bz1994
CalgaryCanada
Post Number: 7
Thank you Stu. I'll go with Marantz.
Now, if I go with SA8004 $1200 instead, would that be worth the money difference. CD5004 is $400.
Need to Register?
Forgot Password?
Enable HTML code in message
