Sony CD Player Won't Plan new CDs?
Username: Keaneasc
San diego , Ca Usa
My SONY C67ES CD Player (10y old and a great player) will not play in new music CDs. Those created by music co's in last 6m...
A music CD version or format that prevents it?
Or am I dreaming?
Username: Nuck
Post Number: 14510
Do the cd's play in your puter to open properties and see what is there?
Username: Keaneasc
San diego , Ca Usa
Hi,
Should of mentioned in the blog - they work fine on the Dell Desktop
I did go back and retest - no on CD and worked fine on PC.
Opened Properties - 10 .cda files only, nothing else.
Username: Nuck
Post Number: 14511
gk, what if you rip a copy of a new cd and try that?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3608
Weird. Does it still play older discs?
If you can see the .cda files, so should your CD player.
Username: Keaneasc
San diego , Ca Usa
Plays every old CD I have very nicely.
I can see the .cda files on the new and old on CDs using the PC but the Sony CD player can not handle the new CDs.
Will try to copy the new CD, create CD and try playing it tonight
Need to Register?
Forgot Password?
Enable HTML code in message
