Rega Saturn or Ayon Cd-1
Username: Scaltinkaya
DeirmendereKocaeli
Hi there,
I'll buy a new cd player. But, I am confused about these two players. I am waiting ideas about players, especially ones who had test two of theme. Which one is for me?
(PS: Deep&wide soundstage and 3 D is the most important isues for me.)
Thanks.....
Username: Hawkbilly
Nova Scotia Canada
Post Number: 793
How did you narrow it down to these 2 players ?
Username: Nmytree
Post Number: 411
Isn't the Ayon CD-1 just a Raysonic CD-168 with a different tube? Seems like basically then same thing.
Username: Artk
Albany, Oregon USA
Post Number: 12024
Never heard the Raysonic or the Ayon, but I can sure recommend the Saturn. Excellent player and can be had at a great price now. I have one and give it my highest recommendation. If you don't need a player and can do with a DAC the Bryston BDA1 would be another recommendation.
DeirmendereKocaeli
I use proac response d15 speaker. And the player price must be between 1500-2500 £. I can say Saturn, but I have not much listening experince. So I need your other brand advices.
Need to Register?
Forgot Password?
Enable HTML code in message
