Bose Acoustimass 7 Subwoofer problem?
Username: Ledfan
So I recently acquired a bose acoustimass 7 subwoofer for pretty much free, but I cannot get it to work for the life of me.
It will not work as a subwoofer, I haven't tested if the cube speakers work via input on this or not yet.
Is there an easy fix to this?
I'm currently attempting(failing) at disassembling the back of the subwoofer because I cannot seem to get it off (the back cover)
any help/advice is appreciated.
Username: Ledfan
I've gotten the back off now, lurking for anything suspicious...
Username: Juachis1
Hi...did you follow up a procedure to take the plastic cover off?
can you help me to take mine off?
thanks.
Need to Register?
Forgot Password?
Enable HTML code in message
