Rca lyra 1076b won't work HELP Please
Username: Nikiwi
I have had problems for a long time w/ getting it to
a. transfer files w/o the sd card being write protected.
b. 50% of the time or more it will only play for about 5 seconds with a new battery and then turn off
c. I did drop it in some water once and tried to dry it, but I guess it messed up the hard drive.
It was after that, the SD card was working part of the time. I have checked and it's not locked or anything. HELP PLEASE!!!1
Username: Project6
Post Number: 15705
"I did drop it in some water once and tried to dry it"
DUH!
Water and electronics do not mix. Replace your player with a new one.
If your issue is with the SD card being write protected, did you check the write protect tab?
And...replace the player.
Need to Register?
Forgot Password?
Enable HTML code in message
