Digital out connector to RCA input
Username: Roddyboy
Woodbridge, Va Us
Is it possible to use my SACD digital out (coaxial), and using a splitter, go to the back of my integrated amp (NAD 372)that only has RCA plugs? What kind of sound should i expect?
Username: Nuck
Post Number: 9855
nope.
Username: Frank_abela
Berkshire UK
Post Number: 2761
Rodney,
For goodness sake don't do this! You can damage your speakers, and possibly your amp. A digital output provides a digital signal. This is of vaguely the same strength (voltage range) as analogue signals but its shape is distinctly different and can cause the amp to dump large amounts of current into the speakers.
I strongly recommend you don't do it.
Regards,
Frank.
