Have monitors, need amp/cdp!
Username: Nodule
I just recently purchased the Silverline Audio
SR12 monitor is Rosenut finish. I now need an
integ amp and cd player. I my funds are limited,
im think my choose with either be Cambridge Audio
640A V2 or NAD C352.
Im wondering if any folks here are fimiliar with
the sound of this Silverline and which amp will
be the right macth?
Im musical tastes is stuff like Sting, James Taylor, Springsteen, acoustic comp. jazz, folk.
NOT hard rock or heavy metal or classical.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12140
What's the sensitivity spec on the speakers?
Username: Nodule
Sensitivity - 87db
Username: Nodule
check out their website at www.silverlineaudio.com
Dallas, TX
Post Number: 12144
Personally, I'd give this some consideration; http://www.sixmoons.com/audioreviews/winsome/mouse.html
It should have sufficient power to drive the Silverlines to a reasonable if not loud level in most rooms. The T-Amps offer very good - and in some respects, excellent - performance for low dollars. Cruise the archives of that site for more information on T-amps and read this, https://www.ecoustics.com/electronics/forum/home-audio/193312.html
If you can manage to put together the Winsome from a kit, the extra money spent should cover a much better CD player.
Can I ask why you bought fairly high resolution speakers and then must scrimp on the amp and source player? Have you never come across the saying, garbage in = garbage out?
